Hey guys,
I recently built my first computer. An excellent learning experience, and I was pretty jazzed when it didn't blow up when I first turned it on. I am having a problem right now with heat. I was hoping someone could help me figure out what the problem might be.
When I play games (in my case, city of villains) or get the CPU going under heavy load, the temps dramatically increase to the point where I turn it off out of fear (steady rise from about 32 up to 60, at which point I power down). I am using PC Probe II (comes with Asus boards) to monitor temps...I usually log out of COV when the temp is on a steady rise past 55 degrees.
The chassis fans are on and working, the heatsink fan is on and working...I can't figure out what it might be. I had read that the stock HSF on the E6600 Core 2 Duo's was more than adequate. Is there something obvious I'm missing? Or does anyone have any more in-depth suggestions?
Here are some things I thought of or got advice on, I'd love comments/suggestions.
1) re-seat the processor
2) remove stock thermal paste and apply arctic silver paste, then re-seat HSF
3) install optional fans that came with mobo (this shouldn't be a requirement for stable temps, though)
any other thoughts, advice, encouragement for a rookie trying to soldier on? thanks in advance..
edit:
I'm a moron, I forgot to mention the most important part of this. When I need to do a soft restart, for instance after I've installed a driver, the computer won't load up. It does the one long beeeeeeeeeep for 20 seconds. I've checked on the internet and found this seems to be related to heat? I have to physically unplug the computer, give it a minute, and then boot it back up. I couldn't specifically find ASUS mobo beep codes, but thats the consensus from my net research.
Thanks again guys, this really helps me out more than you know.
edit:
