Archived from groups: microsoft.public.win2000.setup_deployment (More info?)
The error during the text portion of the setup:
"the image selected does not contain drivers for your hardware"
What I've done to solve it:
Following directions from previous posts and MS Qs I have downloaded the
correct drivers from Intel and added them to the CD Base image i386
directory. I also added the $oem$ paths and drivers at the same level as
the i386 folder on the base image and updated the sif file with the
oempreinstall=yes. I also followed the direction on Intel's site regarding
a corrected inf file and have replace it per their directions. I can now
ris a base image to this computer without any problem.
Nevertheless, if I riprep an image up to the server. I can not bring it
back down to the client again. I get the above error. What is confusing to
me is that I though the CD base image was being used during the initial text
mode setup. If it works on the Base image why doesn't it work for the
riprep image?
Jeff,
What Intel NIC are you using? I get a similar problem from
an Intel Pro/100 VM onboard NIC.
>-----Original Message-----
hardware"
downloaded the
image i386
the same level as
file with the
can not bring it
work for the
>riprep image?
>Any help would be greatly appreciated.
>Jeff
I'm using an Intel Pro/1000 MT.
"Chris" <anonymous@discussions.microsoft.com> wrote in message
news:5a9801c48a83$0add9860$a301280a@phx.gbl...
> Jeff,
> hardware"
> downloaded the
> image i386
> the same level as
> file with the
> can not bring it
> work for the
>>riprep image?
>>Jeff
Did you overwrite files that were already there? If so, did you delete the
*.pnf files that are in the i386 directory and restart the BINL service?
I've had some drivers be very picky. When you RIS the base image are all
drivers present? Does the warning say "no drivers for your hardware" or
"none for your network card"?
I sometimes copy a driver folder to the RIPREP RIS image and then alter the
sif to point there.
My site has granular instructions, but not drivers for your card:
>> hardware"
>> downloaded the
>> image i386
>> the same level as
>> file with the
>> can not bring it
>> work for the
>>>riprep image?
>>>Jeff
Hi Scott thanks for the post. To answer your questions, yes I deleted the
pnf files and restarted the BINL service. After I image the base image all
the drivers are present and working. The system adds itself to the domain,
the nic drivers, video drivers and sound drivers are all there and properly
configured. It's only with a riprep image that it doesn't work. I haven't
tried moving the driver folder to the riprep image and modifying the sif. I
will give it a try.
Thanks
Jeff
"NIC Student" <nospam@nospam.land> wrote in message
newsE1i6u3iEHA.2052@TK2MSFTNGP15.phx.gbl...
> the *.pnf files that are in the i386 directory and restart the BINL
> service?
> the sif to point there.
> www.mvps.org/serverstuff >
> Scott Baldridge
> Windows Server MVP, MCSE
>>> hardware"
>>> downloaded the
>>> image i386
>>> the same level as
>>> file with the
>>> can not bring it
>>> work for the
>>>>riprep image?
>>>>Jeff
You might rebuild the RIPREP image and try again. Let me know how it goes.
Scott Baldridge
> all the drivers are present and working. The system adds itself to the
> domain, the nic drivers, video drivers and sound drivers are all there and
> properly configured. It's only with a riprep image that it doesn't work.
> I haven't tried moving the driver folder to the riprep image and modifying
> the sif. I will give it a try.
I have rebuilt the image but still no success. I'm tired of fighting with
RIS. I do appreciate your help Scott, however, these newsgroups are
supposed to be managed by MS pros; they are proving to be worthless. We are
a dual shop with both Novell and MS servers. Maybe ZEN works will be
better.
-Jeff
news:eOkNn5GjEHA.1404@TK2MSFTNGP09.phx.gbl...
> goes.
> Scott Baldridge
>> the pnf files and restarted the BINL service. After I image the base
>> image all the drivers are present and working. The system adds itself to
>> the domain, the nic drivers, video drivers and sound drivers are all
>> there and properly configured. It's only with a riprep image that it
>> doesn't work. I haven't tried moving the driver folder to the riprep
>> image and modifying the sif. I will give it a try.
