well it's not important but just wondering how much power does 8800 gts 320 consumes. i have EVGA 8800 gts 320 MB superclocked. i know pci express can supply max 75 watts and the 6 pin adapter too can supply 75 watts max. so it can't be over 150 watts. but it is over 75 watts for sure lol
There has not been any official power measurements of the 8800 series. NVidia states the 8800GTX consumes a max of 145w. The 8800GTS 640MB consumes 115w, therefore the 8800GTS 320MB should consume less than 115w under the worst possible load.
The website does not provide any specs or a picture of the PSU.
You will need to look at the sticker on the PSU to determine how much power the PSU can provide on the 12v rail(s).
Below is an example from the Enemax FMA 535w PSU:
As you can see, this PSU has two 12v rails. Each of which can provide a max of 22 amps. However, it can only provide a max of 34 amps combined. It is not as simple as adding 22 amps on both 12v rails for a combined total of 44 amps.
44 amps would mean that this PSU would be able to provide 528w on the 12v rails; 44 amps x 12 volts. No way in hell will that happen.
Watch what you say, as not all PSUs are made equal...
Quite often the wattage the cheaper brands state is peak and not sustainable. Antec NeoHEs look pretty good though. I was thinking of getting myself one if I decide to go ahead with an Easter build!
So you'd be looking at something that has 20amps and 18amps on respective 12 rails.
A 450W Antec PSU is much stronger than a generic 550W. Don't get fooled by large, theorical and often unreliable wattages; it's precisly how much amperage it can deliver to your video card that counts.
Back to the original question...
I have a kill-a-watt meter on my PC (not extremely accurate but it's close). Running Prime95 on both cores, my system draws between 175-180 watts. While playing battlefield 2142 at high rez, it draws between 235-245 watts. That should give you a rough estimate.
-G
E6600 stock
2x1GB DDR2-667 4-4-4-12
DVD Burner
Seagate 320MB 7200.10 SATA
Sound Blaster 2 Audigy
eVGA 8800 GTS SC 320MB
Viewsonic 22"
Ultra V500 PS (28A on single 12v rail)
I should also add (for power consumption calculations) that I don't have any fashion show crap like LED fans, color case lighting, etc.
