It's my 4th build, but more ambitious than the first three. I can't do a clean install of xp, get many errors - can't read files, can't copy files, can't install files. Blue screens, crashes, etc. Where have I gone wrong? What else can I try? My goal was a dual boot with Vista on a separate drive, but that crashes during install too. When I managed to get a pretty bad install of xp, same problems with drivers.
Started when a dvd drive shorted out, took out the PS and Mobo. I started upgrading piecemeal, all that is really left from before is the case.
Intel BX2
C2d e6400
2X 1gb kingston value ram, ddr2 6400, 800 mhz
Evga 7900 gs ko
Ultra 550w PS
Sony dvd / cd
Seagate 300gb 7200.10 SATA
Scorpio case?
I've stripped out everything but the above in case it was PS, but 550 w should be plenty for what I have hooked up (took out 2 SATA HD, 2 gb RAM, PCI card and Modem). Bought a new dvd drive, didn't help. I've flashed the Bios to the latest version, checked SATA drivers to be sure I had the right versions for xp and vista, I've formatted the drive each time to be sure I was starting from scratch. I'vve tried it in and out of the case.
I'm so frustrated, I don't know what to try next! I'm not really interested in OC, so everything is on default settings. What can cause so many errors? Help! Please.
Intel BX2
C2d e6400
Evga 7900 gs ko
Ultra 550w PS
Sony dvd / cd
Scorpio case?
