Tom's Hardware Forums » Motherboards & Memory » Asus » need help. having problem with asus n1l64-sli ws motherboard
Add a reply
 Word :   Username :
Bottom
Author
 Thread : need help. having problem with asus n1l64-sli ws motherboard
Profile: stranger
More Information
I had recently bought asus n1l64-sli and fx74 combo, from newegg. my spec is motherboard-n1l64-sli ws, cpu is dual fx74, hd is wd 10000prm 150gb, ram is kingston 2x1gb hyper memory video card is 8800gtx, ps is 850w thermaltake. After i put it all together and now im loading xp home edition 32bit. after copy windows' file and typed product key computer should restart let me create user account, and everything after restart gives me blue screen then just reboot itself. i tried in safe mood it works. windows will start up fine. just not in regular mode. and i had try different memory, different hd, it still gives me same error. then i went to asus website check the bios version, but according to asus the version should work with those cpu. does anyone know about this problem, please helps me. i  spend $3200 on this computer and cant work it works, feeling very sad. please help me. thank you
Related Pr oduct
Add a reply
Google Ads
