Hi
Can anyone assist me with a problem that I have in getting my system to recognise the full 400gb of my hard drive?
This is my first home build and everything has gone well except for partitioning and formatting my hard drive.
I have a Western Digital Caviar SE16 400GB SATA II 7200RPM 16MB Cache. The rest of my system consist of:
1 - Motherboard = Asus P5B-E Intel P965 LGA775
2 - CPU = Intel Core 2 DUO E6400 2.13GHz Conroe 1066MHz FSB 2MB L2 Cache L
3 - Memory = LEMEL DDR2 1GB PC2-6400 (x2)
4 - Graphics = Radeon X1650 Pro 256MB PCI Express
5 - Lite-on 165H6S 16X Dual Layer DVDRW
6 - 450w PSU and iCute Case
When I tried to install my windows XP Pro (which is an older version still requiring SP1 & SP2) Windows only recognises about 137Gb on my hard drive.
I then tried the Western Digital download to create a bootable CD with the Data Lifeguard Tools 11.2 for DOS (CD) downloaded from WD and burned to a CD.
However, when I boot from this CD I just end up at the C prompt of DR-DOS.
If I then run FDISK the maximum size of a partition is only about 8Gb.
So, Question - How do I go about preparing my 400Gb HD for use?
Thanks
Thanks
