Memory problem
Last response: in Windows 7
November 28, 2009 8:45:02 AM
Hello, I have a question about the Modified Pages value on a Windows 7 system. Modified Pages seems to grow without bound after a few days of leaving the pc on until it hits the physical memory limit, then the system pretty much grinds to a halt due to low memory. Imagine booting win 7 at 35% RAM usage which increases to bout 70% at idle after 1 day and then 96% after bout 4-5 days
Any idea what's going on? Is there a way to remove cached memory without restarting? Or set some limits?
More about : memory problem
a b $ Windows 7
November 28, 2009 2:17:30 PM
Are you looking at the task manager for your usage?
My system has been run 24/7 for nearly 2 months now and my idle is at 0%
m
l
November 28, 2009 2:19:56 PM
task manager system resource
m
l
a c 130 } Memory
a c 416 $ Windows 7
November 28, 2009 9:48:35 PM
mine never goes above 14 %!
m
l
November 29, 2009 4:38:26 AM
sounds like a memory leak. what background programs are running?
something isnt doing as it should, you need to find out waht and remove it.
m
l
