I just completed the install of all my components in the case and turned the PC on and all I get is a loud squeal from the PC. Does anyone have the same MB that can help diagnose what I may have hooked up incorrectly?
Nothing shows up on the monitor (blank screen).
The LCD on the MB cycles through codes while the noise continues, but stops at a 7F.
Components:
Vista Home Premium 32bit
Antec P180 case
Intel E6600
EVGA 680i AR MB
EVGA 8800GTS GC
4-1 gb OCZ titanium sticks
2-320gb WD HDD's
Antec TruePower Trio PS
Tuniq Tower 120 HS
Samsung Lightscribe DVD
Components:
Antec P180 case
Intel E6600
EVGA 680i AR MB
EVGA 8800GTS GC
2-320gb WD HDD's
Tuniq Tower 120 HS
