Can someone estimate the power consumption the following components are using?
Athon x2 3800+ (Windsor) (ADA3800CUBOX)
3 - 80GB IDE Maxtor Hard Drives
4 - 250GB Western Digital Sata (WD2500KS)
DVD Burner
4GB (4 X 1GB) OCZ Platinum Revision 2 (PC2 6400)
ICY DOCK MB453SPF-B Internal 3 Hot Swap SATA I/II
GIGABYTE GA-M51GM-S2G
SAPPHIRE 100176L Radeon X1950PRO 256MB
4 - 80mm fans.
Best Guess?
I have a Enermax 600watt power supply that has been fine. The thing is I can't seem to find a UPS that will handle the load.
DVD Burner
4 - 80mm fans.
Best Guess?
