Hey all!
I have decided to build my first system in a LONG time - last time I built my own I purchased a Celeron 300Mhz! My current box is a Dell 2.8GHz P4 with nVidia 6600GT (128mb) AGP, 200GB IDE drive, etc...
I have been reading THG and the associated for forums for a few weeks now. I think I have my build figured out, but wanted to make sure. Any help would be appreciated!
I am trying to build a decent gaming machine - but it doesn't have to be over the top. I play EQ2 (may move to Vanguard soon), but my time is pretty limited so I end up doing a lot internet surfing/email/Quicken mostly.
I am thinking of overclocking - but not to any extremes. Maybe add 10% type of thing.
Here is what I have picked out:
Case w/ power supply: Antec PERFORMANCE TX TX1050B (http://www.newegg.com/Product/Product.aspx?Item=N82E16811129158)
CPU: Intel Core 2 Duo E6600 (http://www.newegg.com/Product/Product.aspx?Item=N82E16819115003)
Motherboard: GIGABYTE GA-965P-DS3 (http://www.newegg.com/Product/Product.aspx?Item=N82E16813128012)
Memory: CORSAIR XMS2 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (http://www.newegg.com/Product/Product.aspx?Item=N82E16820145590)
Graphics Card: MSI NX8800GTS-T2D640E (http://www.newegg.com/Product/Product.aspx?Item=N82E16814127225)
Hard Drive: Seagate Barracuda 7200.10 ST3320620AS (http://www.newegg.com/Product/Product.aspx?Item=N82E16822148140)
DVD Burner: LITE-ON 20X DVD+R (http://www.newegg.com/Product/Product.aspx?Item=N82E16827106050)
O/S: Windows XP
:?: What am I missing? :?:
Do I need to purchase a separate fan for the CPU?
Is this memory compatible?
Is the power supply big enough?
Can I scale back to a E6400 and still have enough CPU speed for the video card?
Thanks in advance!!!
O/S: Windows XP
