Appoximately nine months ago I upgraded my GPU from an Nvidia 4600 to an ATI X1600. When I made this upgrade, I installed an A-power 450 watt PSU. The PC functioned flawlessly for about three months until the PSU blew out one might while I was playing a game on the PC.
I went back to the retailer who sold me the PSU, and they gave me a free 600 watt A-power PSU. That PSU lasted for about five months. It blew out last Wednesday. I returned the 600 watt PSU back to the retailer yesterday, and they were kind enough to give me a better built 650 watt A-power PSU. I hooked it up and my PC functioned well for three hours or so. I left the PC on, and went to bed.
When I woke up, the computer would not turn on. I believe the problem to be another PSU failure, but my room did not smell of smoke (which accompinied the other PSU failures) How can I sure it is a PSU related problem -- the comp worked fine for over three hours.
What could cause these PSU's to burn out in such a rapid succession? Could something else be wrong with my PC?
UPDATE: WHEW, LOL! Well, there is DEFIANATELY something wrong with that PSU that just blew out. After I got done posting, I went back into my room and tried to turn the PSU on for the fifth time today (I had tried earlier today to no success). When I hit the power button, about six inches worth of sparks, a huge EXPLOSION almost, ERRUPTED out of the back fan of the PSU. My arm almost got shocked!
It has a 20+4 ATX connector. It's rated high on 3.3 and 5 Volt which means it an ATX 1.1 PSU that has been 'upgraded' as they claim it to be both ATX1.1 and ATX2.03 compliant. It's on sale for US$10.
If you look at the specifications it says as one of the last things:
"This power supply does not have any regulatory approvals"
To me this means I wouldn't touch that brand with a stick.
That you have blown 3 of them within a year and all of them are more then plenty for the system you use it in tells everything.
That system you post should be able to run troublefree on a Codegen (very cheap brand here in Denmark, Europe) 400Watt model and I wouldn't touch that PSU with a stick either.
Do a last check that nothing is shorted inside the case including on the back of the mainboard and then get a new PSU of some other brand.
