Yo
I have 3x 80mm and 1 x120. My case only support 1 x 120mm and 2x80mm. Two of my 80mm are 0.15 and my other is 0.07 i think. Then my slot at the back has a few more airflow holes than the one on the side. So i have a real dilemma working out which fan should go where. Im also trying to reduce the noise of my machine as well.
My 120mm is blowing in and the 80mm's are blowing out
So if you could tell me what temps are good on SPEEDFAN i could then experiment
I am getting these sorts of temps with my two most powerful but noisy 80mm fans and my 1x120mm
http://img256.imageshack.us/img256/885/untitledcv8.jpg
thanks for your time
Ed
my setup
ok this is my setup
Gigabyte Intel SKT775 965P-DS3 PCI-E SATAII 8Channel Audio Virtual Dual BIOS ATX
Sapphire X1300 XT 128MB GDDR3 VGA DVI TVO PCI-E
Intel Core 2 Duo E6400 (2.13ghz) Socket 775 FSB1066 2MB Cache Retail Boxed Processor
Hiper 580W Type-M Black PSU - SLI Certified with APFC
Crucial 2GB kit (1GBx2) DDR2 PC2-5300 CL=5 UNBUFFERED NON-ECC DDR2-667 1.8V
Casecom KB-7720BK Black ATX Midi Tower Case - No PSU
Ed
my setup
ok this is my setup
