i unplugged a dvd rom without switching the machine off - don't tell me... it was stupid of me. it crashed the pc and from then on it would crash all the time - never stable for more that a couple of minutes.
for months before that happened the fan on my ati 9800pro gpu had been whinning and looked pretty baked. i left it running since it seemed to still be doing its job.
i fixed a new fan to the gpu and the crashing stopped. at the time i noticed the chip on the card looked a bit burnt the surrounding circuits around the chip were a slightly browned.
i am currently having the following issues that i really need to fix:
* running a wireframe maya test, i can only get 25 fps - 1 year before i got 130fps
* i have run with another older card (nvidia FX5600U) and i get the same result
To add a further complication i have recently just installed windows before all this happened.
I need to know how to fix this problem.
I have run sandra engineer 2007 all voltages seem ok.
Any suggestions would be most appreciated - thanks.
