Intel Core 2 Duo E6600 Conroe 2.4GHz = $313
EVGA 122-CK-NF68-TR LGA 775 NVIDIA nForce 680i SLI ATX Intel = 230
http://tinyurl.com/39h29x
CORSAIR XMS2 DOMINATOR 2GB DDR2 800 = $259
OCZ GameXStream 700W = $150
eVGA 8800GTX = $570
Seagate Barracuda 320GB = $90
http://tinyurl.com/qr268
COOLER MASTER Centurion 5= $50
SAMSUNG 18X DVD±R DVD Burner With 12X DVD-RAM = $31
http://tinyurl.com/2lymy9
XP PRO
Total: $1,837
Reason I gave links for Mobo, HD, and DVD is because was wondering if it had enough cables?
Budget is 2K so if there's anyroom for improvement then I can do it up to around $200.
As always there is always room for saving, so if you know anything that is just as good as cheaper, just say. Or if I'm missing something.
EDIT: Would Sanji's Quad-Core be a better choice?
eVGA 8800GTX = $570
XP PRO
Total: $1,837
