Yes No
Ads
Tom's Hardware > Forum > Windows 2000/NT > General Discussion > Win 98 to win 2000 pro upgrade log in problem
Forum Windows 2000/NT : General Discussion Win 98 to win 2000 pro upgrade log in problem
Archived from groups: microsoft.public.win2000.setup_upgrade (More info?)
I upgraded from win 98 to win 2000k and all went smoothly
until I got to the log in screen when win 200k pro
started up. I cannot og into win 2k pro! I never set a
password and user ID on win 98. How do I get past the
screen and log in? I tried using the usual admin/password
and others. Can I back the installation to win 98 or am
I totally screwed and have to do a clean upgrade? I did
back up my data files but do not want to re-install
everything.
Thanks and Best Regards.
Jim
Reply to Anonymous
Hello Jim,
You should have been given the oportunity to enter a password for the Windows 2000 administrator
account. If by chance you clicked throught this screen then the password would be blank. Try
username=administrator and password='"blank".
David Hancock [MSFT]
Microsoft Server Setup Team
Search our Knowledge Base at http://support.microsoft.com/directory
Visit the Windows 2000 Homepage at
http://www.microsoft.com/windows2000/default.asp
See the Windows NT Homepage at http://www.microsoft.com/ntserver/
NOTE: Please reply to the newsgroup and not directly to me. This allows
others to add to and benefit from these threads and also helps to ensure a
more timely response. Thank you!
This posting is provided "AS IS" without warranty either expressed or
implied, including, but not limited to, the implied warranties of
merchantability or fitness for a particular purpose.
The views and opinions expressed in this newsgroup posting are mine and do
not necessarily express or reflect the views and / or opinions of Microsoft.
Reply to Anonymous
Been there, done that, got the T-shirt. I simply cannot
log in to the system. I tried to repair the install as
well. Is there a way to reinstall or back out to win
98?
>-----Original Message-----
>Hello Jim,
me. This allows
helps to ensure a
expressed or
warranties of
Reply to Anonymous
No, not possible.
Regards,
Dave Patrick ....Please no email replies - reply in newsgroup.
Microsoft Certified Professional
Microsoft MVP [Windows]
http://www.microsoft.com/protect
| 98?
Reply to Anonymous
Hello Jim,
Mr. Patrick is correct...there isn't a way to roll-back a 98 to 2000 upgrade. As for the password issues
the only supported way to fix this is to reinstall the OS. You might want to jump on the internet and search for a 3rd party utility
that will allow recovery.
Sorry I wasn't more help
Reply to Anonymous
There are 1841 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Restoring an acronis image of NT 4.0
By hang-the-9, 29 days ago:
After you do the restore, before booting the image, boot off an NT 4 CD, start a command...
Best offers
