Pump:Eheim 1048
Radiator:Black Ice Stealth GTS 240
Water Blocks-
CPU:AquaExtreme MP-05 LE or Danger Den TDX or Swiftech Apogee
Northbridge: Swiftech MCW30
Reservoir:T-Line with fill port reservoir or Danger Den Single 5 1/4" Bay Reservoir
Coolant: Fluid XP+ Xtreme
Tubing:10ft Tygon 1/2"
Hose Clamps:15 Plastic Snap Tubing Clamps
(installation will be done in a thermaltake armor case)
This is what i came up with after a little research so let me know if theres anything wrong with it.(First time buying watercooling)
I'm looking for a very quiet and high performance watercooling setup for my cpu and northbridge. I'm not sure about the waterblocks and reservoir yet.How does the aquaextreme flow rate compare to the tdx or apogee?Also would it slow it down if i had a bigger reservoir instead of a t-line and fillport resevoir?Would the swiftech MCW30 work on an asus p5w dh delux motherboard with 975x chipset?I've heard about accelerator plates/nozzles,do u think i need them and if so which one would work best for my setup to acheive the highest flow rate.?
From all the comparisons that I have seen the apogee seems the be the best. That is way I bought one and I have seen my temps drop a few degrees below ambient temp...idling of course. Instead of the Eheim pump check out the DD Mag II, it is quiet and move a very good amount of water. For the liquid I suggest MCT-5 or MCT-40 because it's cheaper and seems to work fine.
| Quote : From all the comparisons that I have seen the apogee seems the be the best. That is way I bought one and I have seen my temps drop a few degrees below ambient temp...idling of course. Instead of the Eheim pump check out the DD Mag II, it is quiet and move a very good amount of water. For the liquid I suggest MCT-5 or MCT-40 because it's cheaper and seems to work fine. |
Ya i was thinking about getting the mag II but i heard they break pretty easily and after a certain amount of time they get noisy.Also about the mct-5 (which i also wanted),i heard it's really bad to breathe that stuff in,read this on the fluid xp site: http://fluidxp.com/index.php?optio [...] &Itemid=25
I don't mind the cost of fluid xp and i'd rather not worry about getting some disease or something from using that.
Hmm, well, from what I'm seeing, you might as well just buy a swiftech kit to save money, or get a better radiator with at least 3 fans (either a thermochill pa120,3 or a bi gtx radiator) to make it worthwhile to go custom
You could always get a dangerden block with three heads on it and a y splitter to channel it properly for the three heads and that would probably get the best performance for your cpu, but I can't say for sure
Take a look at the Swiftech minires. It is inexpensive, well made, works great and fits just about anywhere. Makes it easire to purge the system if you have a reservoir. The Apogee is a very good block and is easy to work with as is the MCW30.
That set up should be more than enough to cool the NB and CPU. Makes sure those plastic clamps fit the outside diameter of your tubing. There is 1/4" wall tubing and 1/8" wall tubing.
| Quote : Take a look at the Swiftech minires. It is inexpensive, well made, works great and fits just about anywhere. Makes it easire to purge the system if you have a reservoir. The Apogee is a very good block and is easy to work with as is the MCW30.
ya that reservoir looks nice
I'm still not sure about the cpu block though.I need to have a water block that provides the highest amount of flow and best cooling for the kind of pump i want to get which is not a very powerful one.Which would be the better choice ?- the swiftech apogee gtx or the danger den tdx
Also,how much better would a black ice gtx 360 or Thermochill PA120.3 be compared to the gts 240 (i may watercool my video card in the future)
I couldn't really say Chris. I have the plain old Apogee and I'll keep running it till it no longer fits the sockets of rots away. Everyone has their favorites and their are some real venomous fanbois aut there but if you match any of the better blocks to the right tubes and pumps the performance differences are minimal.
If that pump is a low flow then make sure you match it with a low flow block and maybe 3/8" tubing. running 1/2' tubing you may want to get a D5 type pump. Lot's of used ones available over at HardForum for $50 -$55 shipped. That's how I got mine. Either that or write the manufacturers and see what they recommend. BTW, that Apogee GTX is a great looking block? Machined aluminum etc. Not sure i like mixing aluminum and copper in the same loop however.
Well, I would say you could assume nearly twice as good heat transfer on the pa120.3, but for the bi, I would go for the 480 if possible (same price range as the thermochill anyways, they aint cheap), but that wuold provide a bit over 1.5times the heat transfer, but unless you have a *peltier, either one at best will take you only to the ambient temp of the room/case, so I suggest only getting a very powerful kit if you are planning on adding a very hot gfx card (not something like a 7600gt) or you are planning on adding a peltier.
Here's a very powerful pump for you though
http://www.frozencpu.com/products/ [...] 30c107s155
950gph muthafuckas
8O 8O you could run your tubing around the case for all I care and that pump would still be going without a sweat
Here's some peltiers
http://www.frozencpu.com/cat/l3/g3 [...] Page1.html
And here's a new water block
http://www.frozencpu.com/products/ [...] g30c85s141
And here's the y splitter I was speaking of
http://www.dangerden.com/store/pro [...] =34&page=1
*****Be sure you have a powerful psu when dealing with peltiers, they draw the specified wattage from your psu and it may push it too hard if you have a relatively weak one****
The Apogee GT show a few degrees cooler than the TDX, that's why I went with it.
Hey taco, the RBX has been out for years.
So...do you use the store bought hard shell for your tacos or do you fry your own.
| Quote : I couldn't really say Chris. I have the plain old Apogee and I'll keep running it till it no longer fits the sockets of rots away. Everyone has their favorites and their are some real venomous fanbois aut there but if you match any of the better blocks to the right tubes and pumps the performance differences are minimal.
The problem with getting a high flow pump is finding one thats quiet and i have no way of telling if it is until i actually hear it in my case,some people say the d5 is quiet and others say its noisy and makes a high pitched wine.I can't tolerate those kinds of noises so would u recommend a more powerful eheim?,cause i want something that will give more than enough power for 1/2" tubing and will give the flexibility to add more to my setup ,such as my video card, later on.
How's the pricing between the two? That's what would make the difference between a few degrees imo, anyways, as I said, unless you have a peltier, the coldest you can get your air/water cooler is down to ambient temps, so no matter how hard you try, in the end, you need a peltier or phase change to go below ambient temps
$5-10 difference for 2-3 degrees. They are both very good blocks and I was very close to going with the TDX for the lucite top, because it looks cool and you can see if it needs maintenance. I just couldn't ignore those few degrees though.
Then I would go for it, $5 for 3 degrees is a bargain for enthusiasts (if only everything worked that way, I'd love to spend $100 and get 60 degrees off my cpu lol ^_^)
The D5 I have is very quiet, just don't run it dry. Run it dry and it hurts the pump (probably why some guys have screeching D5s and others don't). The D4 was pretty loud from what I have heard.
If you plan on including a GPU in that loop then definitely get a strong pump. You'll need the pressure to get everything through the loop with decent flow. You don't want too much flow and you don't want too little, you ned to balance it as best you can keeping in mind that the blocks are designed to work at a certain flow rate. I'm not sure about that $100 pump Taco was showing above as it would be really pushing the liquid and it may be too strong for the blocks to work efficiently.
That rad needs some strong fans, don't go with the quiet ones. It is a thick, dual pass rad and a low speed fan will not ventilate it effectively. You have to push that air through all those fins so match it up with the manufacturer's recommended CFM rating fan. I like those Deltas that Swiftech sells as they are cheap, not obnoxoiusly loud and push some air.
I think,after looking at reviews for a while, I've decided on getting the Swiftech MCP655 Pump on newegg for $60
Do u think i should go for the triple radiator incase i add my video card which will be the r600 btw (if it ever decides to come out)?,if so which would be better-the black ice gtx 360 or Thermochill PA120.3,i plan on using 50-65cfm fans.
I don't know if that's a good idea, that pump barely profides any gph, I think it's something like 350, either get the 550gph hydor (which is actually less than the swiftech) or the 950gph hydor, both are excellent and way excede the swiftech in price:gph
I think you'll be fine on a pa120.3 for a cpu and gpu only loop, you still may want to add a peltier on, but you'll definitely want a powerful pump and perhaps a lot of tubing to have more water to displace heat. I suggest you get 3 yate loon fans to go with the pa120.3, they're dirt cheap and noctua gets their fans from yate loon then simply volt mods them, something you can easily do
i thought that the MCP655/d5 pump was considered powerful, especially compared to the Eheim 1048 i originally wanted.
950gph?,thats insane,wont that be loud?Its gonna sound like F***** Niagra Falls..lol
Then go for the 450gph hydor, it's still cheaper than the swiftec anyways, but I don't think it would be that loud, e especially if you have a nice case
if i added a peltier how much lower would my temps be? ,how do u install them and what are the risks of using them?
I think what he has got planned out is good
and a swiftec micro res is nice or a T line is fine if thats what he wants
Peltiers use a lot of electricity and if uncontrolled, and depending on how strong they are, they can cause condensation and frost on the mobo. Depending on the strength of the Peltier you are using you may need to insulate the entire mobo.
There are some models out there, sold as a packaged HSF units, that shut the peltier off 10c above room temp to avoid condensation problems. They seem to work pretty well.
I would recommend you hold off on the Peltier. It is an extreme solution requiring specialized hardware, possibly a secondary PSU and a lot of knowledge. They are also prone to failure. If you go that route then do a lot of research and get an experienced guy to help you out and give you some pointers.
Personally, I would recommend that you get experienced using watercooling and learning all the ins and outs of that before attempting Peltier cooling. If watercooling doesn't give you the performance you want then you can modify down the road and stick a Peltier in the loop. I think what you'll find is that the CPU, on water, will peak long before the temps become an issue.
| Quote : Peltiers use a lot of electricity and if uncontrolled, and depending on how strong they are, they can cause condensation and frost on the mobo. Depending on the strength of the Peltier you are using you may need to insulate the entire mobo.
ya i agree with you, i can always do that later when i gain the experience,for now i'm just gonna stay with the watercooling.
ok,so far I plan on getting a swiftech apogee gt or gtx cpu waterblock,a Swiftech MCW30 chipset waterblock,a thermochill pa 120.3 radiator,fluidxp+xtreme coolant,1/2" tygon tubing,plastic snap tubing clamps,either the Danger Den Single 5 1/4" Bay Reservoir or the swiftech micro res,and i still dont know what to do for the pump.I've heard alot of bad things about the reliability of the hydors and thats definately something i dont want to deal with especially since its my first time doing watercooling.The only things i've ever heard bad about the eheim pumps were that they were big and made a little vibration.If its necessary to get such a powerful pump then i could get the eheim 1260 which is 634 gph.If i decided on getting this how noisy would my computer be?I'm not looking for a dead silent computer,i actually like having some kind of noise as long as its not too loud and its not some kind of annoying sound.also, should i replace some of the plastic fittings that come with the waterblocks/reservoir.If so then what should i buy,just the danger den highflow fittings?
One of the great things about the apogee is that it is very effective with a low flow pump. I still recommend the Mag II, it has been working great for me and it is whisper quiet.
I'm not gonna go with a high flow pump.Theres almost no advantage accept for making it a few degrees cooler and i want something quiet.I just want to know which pump will work best for my situation(1/2" tubing, a triple radiator,1cpu block,1 nb block,and possibly a video card block in the future).If u had to chose from these in my situation what would you get? the swiftech mcp655(317 GPH),the eheim 1048(158 gph),or the eheim 1250 (317gph).
I found this video of the mcp655/d5 pump on google video: http://video.google.com/videoplay? [...] pump&hl=en Can someone verify if this is what this pump actually sounds like at full speed or did this guy just do something wrong,like leave too much air in.
I also found a video on the Hydor L30 II Pump (320gph) which is much quieter and has a much less annoying noise to it then the d5: http://video.google.com/videoplay? [...] ydor&hl=en
still cant find anything on the eheim pumps though.
That is the 650 pump in the video which is the D4 and yes it was very loud. The 655 is a D5 and it is much quieter. D5 was produced to fix the high noise of the D4. The D5 even has a dial on it to lower the RPMs if there is any noise but I run mine at top speed and it is very quiet. Go to the Swiftecg site and look up 655 for a full explanation. http://www.swiftnets.com
I would go for whatever is quiter or cheaper, since the hydor seems to do so, I would go for that, but fix your links, they're broken :? I had to listen to the boring voice of 3d game man for like 20min just to hear the system
| Quote : That is the 650 pump in the video which is the D4 and yes it was very loud. The 655 is a D5 and it is much quieter. D5 was produced to fix the high noise of the D4. The D5 even has a dial on it to lower the RPMs if there is any noise but I run mine at top speed and it is very quiet. Go to the Swiftecg site and look up 655 for a full explanation. http://www.swiftnets.com |
ya good thing u pointed that out cause i was gonna stay away from the d5,but i read about the problem they fixed on there website and many other people have said its silent so i'm pretty sure thats the one im gonna get now,i'm gonna be making a big purchase from newegg soon so i'll just buy it then and if i dont like it ,which im pretty sure i will,i can always get a refund.
Well, I suggest you at least take a look at frozencpu's inventory first, they have a far better selection of cooling products, and you may find say a different block you like, or the tubing you have been looking for or whatever, maybe even cheaper prices, I just suggest you do that before purchasing, other than that, you have taco's seal of approval
to build yourself the ultimate watercooling system your money can buy
Enjoy it, and I want results once you're done staring at after it's all set up
I second FrozenCPU. Incredibly fast shipping, great prices and huge selection. Xoxide is also very good.
True, the tuniq is $10 less there than on newegg, but frozencpu by far has the best selection and variety of parts for any type of cooling, though xoxide sometimes has better deals, and I love operation X, though you have to stay up all night, you get the best prices hands down
One thing more about FrozenCPU, besides good prices and an incredible selection, they ship faster than any other e-tailer I have ever used. Every order I have placed with them has shipped ON THE SAME DAY! I've waited two days for Newegg to ship. Xoxide is nearly as good. I use Newegg a lot but I go to the Ox or FrozenCPU if they have what I want.
Well, I haven't ever had newegg delay my order unless it was on a weekend, in which case they always wait, but frozencpu has a large inventory and ships great along with xoxide (which ships on saturdays
FrozenCPU is an excellent e-tailer. Great choice going DIY.
yup, rated numberone in my book for cooling and case modding stuff, closely followed by xoxide (and you can't beat the pricing on operation X either 8) )
Xoxide is like one big sale. FrozenCPU is the first place I found Noctua stuff so I am sticking there and they have great stuff.
Yeah, that's the problem with xoxide, they don't have the greatest inventory
Now I just need to find a place in the USA thatsells Aqua Computer and PolarFlo liquid cooling system components. That way when everyone else is upgrading their 8800GTX to an 8900GTX I will be working with my dad's friend who is a blacksmith (incredibly elegant work) to make my liquid cooling setup.
Aqua Computer Aquatube
PolarFlo TT Three Port CPU Block
Custom North Bridge Water Block
Custom South Bridge Water Block
HDD Water Blocks for my Cheetahs
Custom Voltage Regulator Water Block
Dual Aqua Computer 8800GTX Water Blocks
Modified Mini Fridge to house the condensor powered passive chilling.
(The coolant will start at the top of the fridge where a pump sits a\that pumps the coolant through a network of copper coils that are submeresed in liquid (haven't decided what yet) that is constantly cooled by two condensors with a simmilar network of coils except they are on a closed loop. The water then exits the bottom of the (water tight) fridge and is pumped to the case.
Uneccesary? Yes. Uber badass? Yes.
Get the dTek FuZion waterblock. In comparisons, it seems to beat out the appogee in a slightly greater amount of benches. Plus, it has the lowest flow restricition of all of the high end blocks.
Radiator, swiftec 2fan or above; thermochill 2fan or above.
Fluid, penatosin G11+ some petrastech Biocide.
Good, respectable watercooling sites:
www.petrastech.com
www.crazypc.com
Both committed to customer satisfaction.
you seriously must be rolling in cash man 8O
no, for that much cooling, I say either thermochill pa120.3 minimum, or bi 480 extreme gtx with four fans, you can't put on like 10 things on the loop on a pathetic radiator, plus, you'll be actually needing say a 950gph hydor pump, so pick wisely since you are seriously putting every component on the loop
I want that radiator cause it looks cool lol. It is just going to be part of the loop. I am a student with 3 jobs to support my computer addiction lol.
If you're really worried about sound, one major thing you can do is mechanically isolate the pump from the case. A lot of the annoying noises come from pump vibration being passed along to the big metal case surfaces and resonating. I've seen quite a few interesting setups, one fellow even hung his pumps from the top of the case on strips of rubber. There are, of course, less insane ways to go about this, but if noise becomes an issue, check that pump mounting and see if you can dampen its vibrations. Air in the lines can cause really annoying sounds too, so be sure to purge and have your resovoir up near the top to catch air if its possible.
College I'm assuming?
Anyways, at least check out the 480, it looks manly to me, especially since it's HUGE That, and it seems to be the only radiator that is worthy of a pimpin' case like the antec p190 that I think someone like you with a massive budget should check out 8)
Hey, sorry to hijack, but can you give me suggestions on a new mouse, I have to choose between the logitech g5, g7, mx518, or a razer copperhead, and since they're all really sweet, I can't decide, any suggestions? I have seen reviews saying the razer's traction is better, then I see reviews saying the reverse, I see great reviews on the g7's wireless capabilities, then I see some that say it flopped, man I can't decide
The G7 is awsome but the Razer DeathAdder is... well... a Razer. The DeathAdder is the $hit. I love that fcking mouse.
Hmm, the front of looks weird, but I don't like razer's ambidextrious copperheads, so I prefer the deathadder over them, but the problem is that the mouse is 1800dpi max instead of 2000, and also it is opticle instead of laser which kinda makes me think twice about it
It never, ever, ever misses a single frame.
And highschool.
They're all good. I love my G5, whereas my brother loves his Adder. Just demo them all if you can and go with what works for you. Don't let the Laser/Optical thing sway you too much, it's primarily marketing. And you'd be hard pressed to notice the difference between 1800 and 2000 dpi.
There are 1082 identified and unidentified users. To see the list of identified users, Click here.
