Tom's Hardware > Forum > Home Theatre > HDTV > comcast cable box setting for audio
Forum Home Theatre : HDTV - comcast cable box setting for audio
Archived from groups: alt.tv.tech.hdtv (More info?)
On the comcast cable box, under menu, under audio, you can select low or
high compression. I listen to audio for tv on DD5.1 home theater. What is
the best setting to use - low or high?
Sponsored Links
On Sun, 26 Sep 2004 22:14:39 -0400, "larrylook" <noemail@email.com>
Lower compression=better sound
Reply to abe
Just try them both and choose for yourself!!
rcbridge
This message was posted via http://www.satelliteguys.us by rcbridge
Reply to Anonymous
> is
When you apply compression, you reduce the dynamic range of whatever is
played. Some people like heavy compression. Radio stations apply extreme
compression. It keeps their broadcast between specific limits.
Generally speaking, if you have a good home theater system, no compression
is the best (i.e. "truest" reproduction). However, if you find yourself
constantly riding the volume control - turning it up during dialog and way
down during explosions, etc., then you should probably apply some
compression. Start with the lowest and see how you like it.
If you live in an apartment and have complaining neighbors, you might have
to go up to heavy compression.
Now... depending upon what cable box you have, the compression settings may
or may not be applied to the digital (optical or coaxial) output. You'll
just have to try it out to see. Switch back and forth between no compression
and heavy compression. The effect is not subtle. You'll know immediately if
it is working.
Chris
Munged email. To reply by email (each "word" a letter):
see jay bee are oh oh kay ee [AT] em ess en [DOT] see oh em
Reply to Anonymous
"FlyByKnight" <FlyByKnight@example.invalid> wrote in message
news:9kX5d.1$Vj2.0@fe24.usenetserver.com...
> > is
may
compression
if
> it is working.
Thanks. I believe when I didn't select compression, I didn't get 5.1
sound - but will recheck soon - I could be wrong. I use optical out from
cable box so will get back to you.
> Chris
Reply to Anonymous
There are 651 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
