DGS-1008D(Switch A)<->DGL-4100<->DGS-1008D(Switch B)
and the router connects to the cable modem/internet. All the cabling done from switch to computers are Cat5e and the cabling between switches are Cat6. No other computers are connected to the router (all computers are connected through either Switch A or Switch B)
The problem I am having is whenever a computer at switch A is taking ~4-10KB/s total bandwidth (2-5KB/s UL+2-5KB/s DL) the computers at switch B would have latency issues but not the other computers at switch A (the latency issues would happen at computers connected to switch A if similar bandwidth is taken at switch B)
I am sure I am missing something here, so any help would be very appreciated.
Your 4100 tries to manage and prioritize traffic using what Dlink calls "GameFuel Priority". It also tries to do other things to give priority to certain applications. My guess... it is "helping" you.
I believe those switches support flow control. See if your pc's nic card does to. If so turn it on an see of it helps. It's located under the advanced properties of the ports driver. Most default to off, and not all support it.
