Tom's Hardware > Forum > Motherboards & Memory > Memory > one stick at 3200 or two at 2700?
Forum Motherboards & Memory : Memory - one stick at 3200 or two at 2700?
ok heres the deal... i just got a gig of ram advertised at pc3200 speeds, and i have left another 256mb stick in the slot running at pc2700. should i loose the old stick and run at higher speeds or should i keep both in for 1.25 gigs? my mainboard is a kt4v on a kt400 chipset.
Sponsored Links
If you keep all the sticks in, they will all default to the lowest rated speed i.e. 2700.
Forget the 256Mb of PC2700, and run your 1Gb at 3200 :D
Reply to 31computers
If you are running Windows, keep the extra RAM for 1.25GB. Although it won't be a big speed improvement, any RAM is so much faster than virtual (hard drive) memory that more RAM is almost always better than faster RAM.
Reply to Mondoman
so i have one reply each way... any more opinions?
Reply to tipoo
Quote :
I agree with Mondoman in this case, and especially since you don't need to worry about dual channel. For this system, more memory is gooder 8)
Reply to XMSYellowbeard
+1 Windows will use the memory increase more then the speed increase.
However, you might want to benchmark a game or something and see what you like.
Reply to CompTIA_Rep
two sticks it is then. thanks guys!
Reply to tipoo
There are 1126 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
