Archived from groups: microsoft.public.win2000.setup_upgrade (More info?)
I am trying upgrade to W2K from Win95. A little background...A friend of
mine gave me a floppy that he has labeled Win98 boot disk. I used this to
wipe out the hard drive on a Win98 computer and I successfully installed W2K.
He had me boot to the A:drive and do a "format c:/u/c and that "blew away",
formatted, the hard drive. I was then able to insert the W2K CD and reboot.
When it booted up to the DOS window, I typed A:\D: and then D:\setup.exe and
I was able to install W2K. Now, I'm trying to do the same on another
computer that is running Win95. I used the same Win98 floppy and it says
that the C drive is formatted. Then I inserted the W2K disk and rebooted the
computer. It gives me three choices in DOS mode...(1)Boot with CD
support...(2)Boot Without CD support...or(3)Type help and hit enter. I've
tried options 1 and 2 and the only one that seems to get me close to where I
need to be is #1. It takes me to the point where I can type A:\D:,
D:\setup.exe, but I get an "error" message saying that it is unable to run
this application in DOS mode. Does anyone have any idea what I can do to get
the W2K setup to run?
Thanks
Brad
Sponsored Links
To do a clean install, either boot the Windows 2000 install CD-Rom or setup
disks. The set of four install disks can be created from your Windows 2000
CD-Rom; change to the \bootdisk directory on the CD-Rom and execute
makeboot.exe (from dos) or makebt32.exe (from 32 bit) and follow the
prompts.
When you get to the point, delete the existing NTFS and or other partitions
found. After you delete the partition(s) abort the install, then again
restart the pc booting the CD-Rom or setup disks to avoid unexpected drive
letter assignments with your new install.
Be sure to apply these to your new install before connecting to any network.
http://download.microsoft.com/down [...] SP4_EN.EXE
http://www.microsoft.com/technet/s [...] 3-043.mspx
http://www.microsoft.com/technet/s [...] 3-049.mspx
Regards,
Dave Patrick ....Please no email replies - reply in newsgroup.
Microsoft Certified Professional
Microsoft MVP [Windows]
http://www.microsoft.com/protect
W2K.
away",
reboot.
and
the
I
get
| Thanks
| Brad
Reply to Anonymous
Tom's Hardware > Forum > Windows 2000/NT > Windows 2000/NT General Discussion > upgrade to W2K problem
There are 846 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 Conrad925 won the Freshman badge
  • 01:00 skythra won the Freshman badge
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
  • 01:00 patlabor44 won the Uniformed badge
  • 01:00 Kiren won the Uniformed badge
  • 01:00 WookinPaNub won the Uniformed badge
  • 01:00 kwadams won the Uniformed badge
  • 21:57 brockh won the Sophmore badge
