I recently purchased a Linksys wireless-g broadband router (wrt54g(?)) and a Linksys wireless-g game adapter (wga54g) for use with both my laptop and Playstation2. Should be setting it up soon with the configuration below and would appreciate any advice and input on my questions (also below).....Thanks in advance.
- WinXP Pro desktop wired to router and DSL in bedroom. PC uses ZoneAlarm software firewall and is hooked up to printer via a serial cable.
- WinXP Pro notebook will connect wirelessly (integrated 1000Mbps Ethernet LAN + internal wireless LAN Mini-PCI Module, brand unknown) and will also use ZoneAlarm software firewall.
- Playstation2 with ethernet network adapter will use the wireless game adapter, which I assume is the same as a bridge only smaller.
- All network components are 802.11g compatible and have yet to be configured.
QUESTIONS:
1. Should I update the firmware on both before installing?
2. Will I be able to print from my laptop through the desktop pc or does the printer need to be connected to the router through some ethernet interface?
3. Will I be able to use MAC address filtering (not sure if this is correct terminology) given that one of the devices is a Playstation2 (i.e. will the linksys wireless game adapter have a MAC address of its own)?
4. Will MAC address filtering provide enough security or should I also consider using passwords and/or encryption? I know that "Enough security" is subjective, so here's some context - I live in a densly populated section of Los Angeles with a decent number of high tech or technically savvy neighbors
5. Should I change the default port(s) that are used and if so which port(s) should I change to?
6. I've detected approximately 5 other wireless networks in my vicinity while on my laptop, is there anything I should do to avoid conflicts?
7. Should I continue using the software firewalls on the desktop and laptop or should I just use the router's firewall or both?
8. Any other setup or security suggestions?
I'd like to avoid using encryption if possible since I do alot of online gaming and have a low tolerance for lag of any kind.
QUESTIONS:
