Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > Opening a Drive by double click- Problems!!
Forum Windows XP : Windows XP General Discussion - Opening a Drive by double click- Problems!!
Archived from groups: microsoft.public.windowsxp.basics (More info?)
Hi. I dont know how or what I've done but since last night, when I go into my
computer to open (by double-click) a DVD or CD-RW drive icon, instead of a
window opening to show the drives contents, all I get is the XP search window
opening asking what I want to look for in the drive. This is the window that
opens when you selct the search option from the Start menu.
What have I done and how do I revert it back to just showing the contents of
the drive when I double-click it?
Any help will be gratefully appreciated.
Sponsored Links
Hi
Please see if the following link to Kelly's web site helps. Please read the
directions at the top of the page:
Line 18 - right hand side
http://www.kellys-korner-xp.com/xp_tweaks.htm
Will Denny
MS-MVP Windows Shell/User
Please reply to the News Groups.
"Shamone 79" <Shamone79@discussions.microsoft.com> wrote in message
news:638B94C2-5185-448A-A5D9-56C245F7C003@microsoft.com...
> my
> window
> that
> of
Reply to Anonymous
Hi. I clicked on 'Search opens when double clicking a file or folder' and a
download window opened. The download file has done nothing to resolve the
problem.
"Will Denny" wrote:
> Hi
> Will Denny
> > my
> > window
> > that
> > of
Reply to Anonymous
Since you top posted I will also.
Did you right click on the downloaded file and select Merge?
news:3BFEE25D-4927-497A-8A85-F9BDC45FB199@microsoft.com...
> a
> problem.
> "Will Denny" wrote:
>> Hi
>> the
>> Will Denny
>> > into
>> > my
>> > of a
>> > window
>> > that
>> > contents
>> > of
Reply to Oldguy
Check /correct/ registry entries:
HKEY_CLASSES_ROOT\Directory\shell
"default" value should be set to "Open"
HKEY_CLASSES_ROOT\Folder\shell
HKEY_CLASSES_ROOT\Drive\shell
"default" value should be set to "none"
Regards
Arkadiusz 'Black Fox' Artyszuk
Reply to Anonymous
Hi. When you say 'Check/Correct registry entries' , How do you do that? I
noticed that in the little list that opens if you right click the drive icon,
that 'Search' is at the top of the list in bold when it always used to show
'Open' at the top. I am a total rookie at this so please bear with me! I just
want it to work like it used to!
> Regards
Reply to Anonymous
Open registry editor (Menu Start -> Run -> regedit) and then you should
browse registry keys mentioned above and correct them. If you are not
aware of registry editing rules you may instead of manual editing just
download http://foxblack.w.interia.pl/regfi [...] iveAct.reg and
then click that file twice to make the changes.
Regards
Reply to Anonymous
There are 1025 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
