ok im running at stock speeds for now to configure speed fan im almost have it right i think
ok at idel TAT core 0 36c to 38c
core 1 37c to 39c
at idel speed fan is reading temp 1 35c ( not ure what it is)
temp 2 26c (this is the tcase )
temp 3 22c (ambiant)(offset +23)
core 0 35c to 37c (offset +15 )
core 1 36c to 39c offset +15 )(Tjunction)
Ambient = 23c
Chipset = 965
C2D = E4300
CPU Cooler = intel stock cooler
Frequency = 1.8 gig
Load = TAT 100% 10 Minutes
Motherbord = GA-965P-S3
Vcore = in the bois i have it set to normal witch is 1.325 but it seem that cpu-z changes from 1.28 to 1.34
under load my temps are
under TAT 100% core0 60c
core1 61c
speedfan under tat 100%
temp1 36c
temp2 53c (tcase)
temp3 22c (ambiant )
core0 62c (offset +15) (Tjunction)
core1 61c (offset +15)
ok i can not give any more stats lol
question1 in the temp giuld it says there has to be a 15c diffrence between the tcase and the Tjunction well i only have about a 10c differance between the 2 at idel and under Tat 100% is that ok??????
question 2 do my speed fan offsets look right???? and what is temp 1??
question 3 in the temp giuld it says there shouldent be a 25c differance from idel to load but i have over that is that ok????
core 1 37c to 39c
Ambient = 23c
Chipset = 965
C2D = E4300
Frequency = 1.8 gig
core1 61c
temp1 36c
temp2 53c (tcase)
