SpeedFan is obiously reporting my temperatures (TCase and Cores) wrong. I'd like to get it configured right, and have the difference between Core temperatures and TCase at 15 degrees.
Judging from this, I believe that Core temperatures are reporting corectly. This is with 2x Prime95 Torture going on.
Thus my guess is that the TCase is being reported incorrectly. Can you confirm this conclusion? I've found where to modify the offsets, how would you recommend modifying the offsets to correct values in SpeedFan?
Some other details:
Ambient: 27 degrees celsius
BIOS idle: 40~41
TAT Idle: 44~45
TAT 100% Load: 68~72 usually 71 and 69.
vDroop: 1,36 -> 1,32 at worst.
Kaerwek
Some other details:
BIOS idle: 40~41
TAT Idle: 44~45
Kaerwek
