Ok, heres the deal: Just built a new comp. Put in a linksys wireless pci card. The problem is it will connect to my my router and the internet for about 4-5 seconds then it loses its internet connection. Then about 4-5 seconds later it will reconnect.
I use the same wireless card on the current computer im using now that is in my basement, wheras the new computer is in the same room as the router. I have switched the cards with the same result on the new comp, and old. I have connected wirely with no problems.
I'm kinda stumped, any help would be great.
