Tom's Hardware > Forum > Smartphones & PDAs > Windows Mobile > Problem with PIE CACHE
Forum Smartphones & PDAs : Windows Mobile - Problem with PIE CACHE
Archived from groups: microsoft.public.pocketpc (More info?)
I recently upgraded my DELL X30 to the new A06 ROM. I backed up everything
and after the upgrade restored everything, then installed several new
programs. After using the PIE, I noticed that I have three folders that
seem to be for the non-WM2003 version.
Windows/Cookies
Windows/Cookies/index.dat
Windows/History
Windows/History/History.IE5/index.dat
Windows/Temporary Internet Files
Windows/Temporary Internet Files/Content.IE5/index.dat
I also have the correct PIE folders for WM2003.
Windows/Profiles/guest/Cookies
Windows/Profiles/guest/Cookies/index.dat
Windows/Profiles/guest/History
Windows/Profiles/guest/History/History.IE5/index.dat
Windows/Profiles/guest/Temporary Internet Files
Windows/Profiles/guest/Temporary Internet Files/Content.IE5/index.dat
I have attempted to delete the offending folders but get the message that
the index.dat file is in use, even though PIE is not running or active. I
examined the registry and notice that the
HKCU/Software/Microsoft/Windows/CurrentVersion/Explorer/ShellFolders entry
for
Cache is set to \Windows\Profiles\guest\Temporary Internet Files
Cookies is set to \Windows\Profiles\guest\Cookies
History is set to \Windows\Profiles\guest\History
Both sets of files seem to have been used today. I saw this happen once
before when I installed some software that used PIE and was written for
WM2002 not WM2003. Therefore, I assume something I installed / reinstalled
caused the problem. My solution before was hard reset and reinstall
selectively all programs. Not the option I want this time.
Has anyone also had this problem? Does anyone know what entry in the
registry is the problem, what needs to be altered/removed/added?
Sponsored Links
> everything and after the upgrade restored everything,
Shouldn't have done the restore. Check your version numbers against
this list of "Fixes and Enhancements":
1. Added feature that allows the WLAN auto power-off feature to be
enabled and/or disabled in the Power applet.
2. Updated the Funk Odyssey client to version 2.00.00.1681
3. Updated the Bluetooth stack to version 1.5.0.4300
4. Added support for Go Daddy SSL certificate
Reply to rene
I do have the latest ROM, I checked the version numbers. I only restored my
application backups, using ACTIVESYNC. I do not believe the upgrade is the
issue it is some application software I installed. I just noticed the extra
folders as I was confirming the upgrade worked.
"René" <Kar98@The-Coalition.US> wrote in message
news:kPgue.1581$W74.931@newssvr30.news.prodigy.com...
Reply to Anonymous
Checked the version numbers of the Odyssey Client?
Reply to rene
I have
Odyssey Client for Pocket PC Version: 2.00.00.1314
news:WQiue.1593$W74.1519@newssvr30.news.prodigy.com...
Reply to Anonymous
Indeed. And if you hadn't restored your old backup, with all the
applications, it would have been 2.00.00.1681
Reply to rene
So, although the other changes were made to the ROM, Odyssey is not. I
will reinstall of the ROM without a restore of the applications. Thanks
for that info.
How will this solve my original PIE folder issue??
news:sLjue.1598$W74.1386@newssvr30.news.prodigy.com...
Reply to Anonymous
> not.
The Odyssey Client update _was_ written to ROM, and still is there.
However, restoring your backup has overwritten (not really, it's just
hiding) the newer version.
> I will reinstall of the ROM without a restore of the
> applications.
Not necessary. A simple hard reset will do. Then re-install your
applications manually, sync to Outlook to get your PIM data back, and
your problem (as referred to in the subject line) will be solved.
If this is of any consolation, I had to do the same because of a
similar problem. The version numbers (other than a few invisible
improvements to Odyssey and the Bluetooth stack, and acquiring a
network connection much faster) were merely an indicator telling me
just what you did.
Reply to rene
There are 1144 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
