I've recently built a amd athlon 3200+ on a winfast mobo. Everything worked correctly, installed xp, etc etc. I updated my mobos audio drivers and now on startup nothing happens! It takes ages to get past post, and starting up from the HDD results in nothing happening.
When POST stalls, it's always a hardware issue. Crack open the box, and check all the connections to make sure everything is secure. That means memory as well as all the cables.
To set your mind at ease about one thing: the mobo audio drivers would NOT cause this.
There is a serious hardware problem.
Settle the issue as to your memory still being good as well. Using another comp, download MemTest - create their cd, and test your ram for at least 4 hours.
