Gadget Gift Ideas For Everyone
Yea this is my first time build..... with an Intel Proc My Budget is About $1000 CND I'm planning on getting a C2D 6400 and have chosen the Ram is gonna be 2G OCZ platinum rev 2 i just don't know what Mobo to get i have been looking between: ASUS Commando ATX LGA775 Conroe DDR2 P965 2PCI-E16 PCI-E1 4PCI DDR2 SATA2 Sound Motherboard ASUS P5B Deluxe / WIFI-AP ATX LGA775 Conroe 965P DDR2 PCI-E16 3PCI-E1 3PCI 8 SATA2 Sound Motherboard DFI LANParty UT ICFX3200-T2R/G RD600 XPRESS3200 LGA775 Conroe DDR2 3PCI-E16 SATA2 1394 Motherboard i currently have a DFI and (AMD 3700+) and i like the DFI board. but i have also been hearing good things about the ASUS i probably will do some OC'ing nothing ELITE though maybe get the processor up to 2.8ghz or so. i would like to keep the mobo under $300 looking for a good feature set and something that is rock solid stable My other parts are BFG Geforce 7900GT ( will upgrade to eVGA 8800 GT KO 320MB) 2 Seagate 80g HDD Sata2 OCZ 600W PSU Antec P180 Case ViewSonic vx2245 Monitor please help me on deciding. things to point out would be pros and cons and problem majorities that people have . also if you can suggest on a board that might be better than those three please throw it in there..
You are about to answer a thread that has been inactive for more than 6 months.If you still wish to proceed, please ensure that your posting is original and does not duplicate or overlap any prior responses to this thread.
