I just built my first machine, Its not the best, but much better than my old
(gateway celeron). I also just installed water cooling but I need to know if this are the right temp i should be getting (I thought it would be cooler but Imay be wrong.) Here are my spec:
Amd 64 fx-62 Oc(3.1)
Asus M2N32-SLI Deluxe mother.
Thermaltake Bigwater 735.
temp 35c to 40c idle.
50c to 55c load.
Thanks.
50c to 55c load.
Thanks.
