I was upgrading my old pc which my son uses, with some 512 sdram pc133 memory and a new processor. It used to have Athlon 850MHz and I got a Duron 1600MHz for £20, the motherboard is a pcchips socket A.
When I changed the memory and the processor the memory displayed correctly, but the processor displayed Athlon 1.2GHz. After consulting the manual I discovered that back in 2001, 1.2GHz was the max and then had a look on the pcchips website for a bios update. I flashed the bios with the new update and it failed to flash resulting in me getting a new bios chip and having it flashed with the updated file.
It now displays Duron 1200MHz and when I go into the bios settings and change the cpu speed to 1600MHz, save, then reboot it hangs and will not load XP. A bit long winded I know, but has anyone any idea how I can get the correct cpu speed to display?
This isn't a state of the art pc by any means, but it does my lad for internet and msn.
