Problem installing XP.
I have a brand new machine and are having problem installing XP. After the install have finished loading the installations files and its about to switch to the step were you can format your disk and create partitions it doest continue it just switches to a black screen with a white - blinking in the top left corner. Anyone have an idea to an solution?
/JeppeK
1 answer Last reply
More about problem installing
  1. Questions first!
    Have you setup BIO's for hard drive yet?
    Do you need to load SATA Driver?
    First, do no harm!
Switch Windows XP Format
