I am having a strange problem with a computer i built for my sister. it works fine at my house but when i take it to her house and plug it in it wont go past the xp splash screen it gets there and just reboots. it stoped working and started this after RCN put a cable modem on it. any ideas could it be a power problem the cable modem?
Sponsored Links
Have you tried removing the cable modem? Is it USB or PCI?
If it worked fine at yours, it can only be
a) A problem occuring in transit - in which case, good luck!
-or-
b) Any hardware changes you've made since the move - I.E. that cable modem
Reply to mesarectifier
- 0 +
Are you using a UPS? Could be bad power coming into the house. Seen it once before, though, not as bad as you are saying.
Open case and reset all cards including memory. And check all of your plugs too.
My old 300 PII used to do the same thing when i moved it for any reason. Have to go in and reset everything.
Just a thought.
Reply to Smeg
Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > crazy XP Problem
There are 915 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
