I am using a D-Link DGL-4300 router with cable modem and recently tried to add security features (WAP2) to it.
I connected to the default IP and made the changes. I was then instructed to 'reboot' the router and it hanged. I let it continue to try for 30 mins but no dice.
I then unplugged the router to reset it but it's stuck in reboot mode (WAN light blinks then all ports blink then nothing then it starts again).
I have pushed the manual reset, reset my cable modem and still the router is stuck.
When I try to connect to a wireless network, the default network is now gone.
I went into windows network config and the default network icon has a red X next to it.
Does anyone have any ideas on what I can do to get the default network back up on the list?
