Does anyone know of any shareware that I can run on demand in XP Pro that will monitor and show the CPU temp and fan speed when I call up the program?
I can use SisOff Sandra but I dont want to launch a program that big.
Thanks.
PS-I have an AMD X2 4400 CPU and an ASROCK mobo 939 DUAL SATA with 2 Gb CORSAIR XMS.
Try MBM5 (Mother Board Monitor). It gives a lot of information in a small package. You can even set it up as a service. They have a feature called dashboard that shows all info needed in a small window using gauge dials.
Thank you. GREAT utility but it makes no mention of my ASROCK mobo, which is in fact made by ASUS. How would I "guess" which ASROCK mobo to select from the MBM list so that I actually receive authentic temperature and fan speed measures? Thanks again.
