Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > Sapphire-Radeon-X1950PRO
right i have my bros computer and its a pentium4 zeon 3.4ghz and it has 1.5 mb ram, well it has an 8X AGP slot inwhich i have a nvidia geforce fx 5700 graphics card. well was just wandering if i brought this graphics card:
http://www.microdirect.co.uk/(1613 [...] x-AGP.aspx
would i be able to play games like oblivion on highest settings?
Sponsored Links
I recently replced my AGP card with that one, at least I think we're talking the same card, Linky
While it does a fantastic job in Oblivion, it won't quit max it out. I think my CPU is limiting me, K7 XP +3000. Was it worth it? YES!! Here's my results...
Another Linky
Be aware it has some high PSU requirerments. Search these forums for further guidance. It helped me out a lot!
DC
Reply to Darkchyld
Hi im looking into the same card for mine and have spent hours on toms main site looking at reviews and asked about in this forum and can safley say that you wont get another card to do any better.
Regarding the psu issue mentioned i have checked this and found some pics on e-bay of a box that says 350 min req
Hope this helps
Mactronix
Reply to mactronix
Quote :
depends on the res. At 1024x768 you can definitely max all the in game settings, but not sure about higher res.
Reply to blade85
There are 1243 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
