Tom's Hardware > Forum > Wireless Networking > Wireless General Discussions > 1st PCI-E Wifi AP combo card! Wireless network card!
Well this has some promise to be a fairly revolutionary product. Not really because its such a technological marvel but the fact that you can actually use those dang 1x slots that have been basically useless (besides some companies using it for MoBo sound). I assume the PCI-X 1x bus is probably the equivalent to a basic PCI bus so the small size is just the result of newer tech.
With only 3 PCI slots because i have PCI-X 16x & 1x and AGP on my board I really wanted to use that lil 1x slot, and hopefully this is my answer.
* ABIT AB9 QuadGT LGA 775 Intel P965 Express ATX Intel Motherboard - Retail
* ABIT AirPace Wi-Fi PCI Express Wireless Adapter - Retail (FREE)
* ABIT KN9 SLI Socket AM2 NVIDIA nForce 570 SLI MCP ATX AMD Motherboard - Retail
* ABIT IB9 LGA 775 Intel P965 Express ATX Intel Motherboard - Retail
* ABIT AW9D-MAX LGA 775 Intel 975X ATX Intel Motherboard - Retail
* ABIT AB9 Pro LGA 775 Intel P965 Express ATX Intel Motherboard - Retail
[L=Free Wifi card Combos]http://www.newegg.com/Product/ProductComboList.asp?ItemNo=N82E16833347001&Subcategory=31&PageSize=10&SortField=0&Page=1[/L]
odel
Brand ABIT
Model AirPace Wi-Fi
Spec
Standards IEEE 802.11b/g, Wi-Fi compliant
Data Rates up to 54Mbps
Security WEP 64-bit and 128-bit encryption
WPA(Wi-Fi Protected Access)
WPA/WPA2 WPA
Interface PCI Express
Frequency Band 2.4 GHz ISM radio band
Channels 802.11b:
USA, Canada and Taiwan – 11(2412~2462MHz)
Most European Countries – 13,
France – 4, Japan – 14
802.11g:
Most European Countries – 13, Japan – 14
Antenna External Antenna
System Requirements Windows XP/server 2003/64bit XP
Dimensions 2.7" x 1.8" x 0.5"
Feature
Features Solid design with external antenna
Low power consumption and high performance
Enhanced wireless security
Software AP mode
[L=http://www.newegg.com/Product/Product.asp?Item=N82E16833347001]http://www.newegg.com/Product/Product.asp?Item=N82E16833347001[/L]
Sponsored Links
There are 1088 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
