Ok, this is a little bit of a thread hijack… but it seems to be a similar question.
I am running Socket 754 Athlon 64 3200 venice core. It is on an Epox mobo that does not allow AGP/PCi locking, so upping the FSB is out of the question. The hitch in the system is that I am running it with 2x512 pc2100 ram. So, it is using a divider to run the ram at 133/266 ddr. Obviously the system would be the best with pc3200, as that would run with a 1:1 ratio.
I am happy with the performance, everything runs great. But I am curious it I “loosen” the timings, could I run this ram at a higher speed…i.e. 166 or 200 mhz?
It is corsair value ram, and I think cpu-z said my timings were 2-3-3-6.
Or should I just leave well enough alone.
Thanks
