Giga Lan Problem
Forum General Networking : Network General Discussions - Giga Lan Problem
Hi all .
I have a Network Cafe 21 Pc , and a switch 1000/100/10 ,i Connected the cables and windows gave me the 1 Gb lan Connected , when users play Any game like fifa or Counter against the pc the game doesnt lag , but when they play it multiplayer on the local network it laggs , not all the pc together but Randomly.
when i ping a pc i get this result:
ping 192.168.1.8
Pinging 192.168.1.8 with 32 bytes of data:
Reply from 192.168.1.8: bytes=32 time=2ms TTL=128
Reply from 192.168.1.8: bytes=32 time<1ms TTL=128
Ping statistics for 192.168.1.8:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 0ms, Maximum = 2ms, Average = 0ms
is this Normal?
My Switch is Assus and Cables are Cat6
Pc Spec:
P 3.4 2Mb*2 Cach
Assus P5pld2
1 Gb DDr2
256 mb X1600 pro
250 Gb Sata II
What is happening? all my Pc are high end and got a very good specification
Plz help
Sponsored Links
Looks pretty normal to me. The first packet where the connection is established is 2ms, the rest all show <1ms.
The PING command does not give values in nano seconds... it's just not intended as a precision packet measurement tool.
Reply to Darth_Indy
you could try running this tool on both of the pcs
http://dast.nlanr.net/Projects/Iperf/
run one wiht
ipeft -c IP_OF_SERVER
and the other
iperf -s
to run it as server
Quote :
iperf.exe" --help
Usage: iperf [-s|-c host] [options]
iperf [-h|--help] [-v|--version]
Client/Server:
-f, --format [kmKM] format to report: Kbits, Mbits, KBytes, MBytes
-i, --interval # seconds between periodic bandwidth reports
-l, --len #[KM] length of buffer to read or write (default 8 KB)
-m, --print_mss print TCP maximum segment size (MTU - TCP/IP header)
-o, --output <filename> output the report or error message to this specifie
d file
-p, --port # server port to listen on/connect to
-u, --udp use UDP rather than TCP
-w, --window #[KM] TCP window size (socket buffer size)
-B, --bind <host> bind to <host>, an interface or multicast address
-C, --compatibility for use with older versions does not sent extra msgs
-M, --mss # set TCP maximum segment size (MTU - 40 bytes)
-N, --nodelay set TCP no delay, disabling Nagle's Algorithm
-V, --IPv6Version Set the domain to IPv6
Server specific:
-s, --server run in server mode
-D, --daemon run the server as a daemon
-R, --remove remove service in win32
Client specific:
-b, --bandwidth #[KM] for UDP, bandwidth to send at in bits/sec
(default 1 Mbit/sec, implies -u)
-c, --client <host> run in client mode, connecting to <host>
-d, --dualtest Do a bidirectional test simultaneously
-n, --num #[KM] number of bytes to transmit (instead of -t)
-r, --tradeoff Do a bidirectional test individually
-t, --time # time in seconds to transmit for (default 10 secs)
-F, --fileinput <name> input the data to be transmitted from a file
-I, --stdin input the data to be transmitted from stdin
-L, --listenport # port to recieve bidirectional tests back on
-P, --parallel # number of parallel client threads to run
-T, --ttl # time-to-live, for multicast (default 1)
Miscellaneous:
-h, --help print this message and quit
-v, --version print version information and quit
[KM] Indicates options that support a K or M suffix for kilo- or mega-
The TCP window size option can be set by the environment variable
TCP_WINDOW_SIZE. Most other options can be set by an environment variable
IPERF_<long option name>, such as IPERF_BANDWIDTH.
Report bugs to <dast@nlanr.net>
Reply to Buzzons
Tom's Hardware > Forum > General Networking > Network General Discussions > Giga Lan Problem
There are 1265 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
