hi
i need help completeing my first home build. currently i have choosen the following
cpu:
AMD Athlon 64 X2 Dual Core 3800+ 2.00GHz (Socket AM2) – OEM- £35.24
ram:
1Gb (2X512Mb) Corsair TwinX XMS2, DDR2 PC5400 (667), 240 Pin, Non-ECC Unbuffered, CAS 4-4-4-12-£45.24
need help finding a motherboard and a graphics card. will like to spend maxium £30 on graphics and about £50 on motherboard as last resort as i would ideally like to spend about £40. also do i need a heat sink as thats oem.
will like to order everything from scan.co.uk or overclockers.co.uk
cpu:
ram:
