download speed issues
Forum General Networking : Network General Discussions - download speed issues
I recently joined sky broadband and was given a netgear adsl router DG834GT together with an 8 meg connection. The computer shows that the router is connected at 8megabits but when I go to test my download at any given site I get a response saying that my download speed is only 0.8mb i.e around 7800 kb. If I go to a UK site I get a reading of around 2Mbps, better but nowhere near the 8Mbs connection I have.
I am connected to the router via a wlan adapter which seems to be connected at 100% strength and quality.
Can anyone please help as ringing Sky doesn't help much as I feel the person I end up talking to knows as little, if not less , then I do. Incidently, they say that I should be capable of downloading at 8Mbs.
Sponsored Links
If you are connected wirelessly, I would run the test with a wired connection before I started pointing the finger at your broadband supplier.
Reply to Iceblue
Quote :
Thanks for the tip. Works a lot faster.
P.S. I wasn't looking to blame anybody although it would have helped if Sky offered the same advice as you just did. They were given the same info as was given this forum. I just wanted the issue resolved. Alls well that ends well.
P.P.S Would the length of a LAN cable adversely affect download speeds?
Reply to wellconfused
just out of interest, why is it that my asus wireless LAN adapter that is rated at 54 Mbps cant deliver the same download speed as a LAN cable. Surely, the 54Mbps far exceeds the 8Mbps connection??????
- 0 +
It should exceed your broadband speed under ideal conditions, but it is more difficult to achieve ideal conditions with a wireless than with a wired.
54Mbps is the raw bit rate of 802.11g. However, 802.11g has high overhead, so the maximum data throughput is more like 22-24Mbps. If you are not right on top of your router in an interference-free environment, your actual throughput can be much less. Less than your 8Mbps, depending on distance, walls, nearby wireless networks, etc.
All I was suggesting was if you want to test your broadband speed, use the wired connection to avoid all the side issues with wireless. Cable broadband is a shared network, so it is also possible your provider is NOT giving you the speed you should be getting at peak usage times.
Even the wired connection has to deal with the WAN to LAN thoughput performance of your router.
Reply to Iceblue
Tom's Hardware > Forum > General Networking > Network General Discussions > download speed issues
There are 990 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 vianescute won the Freshman badge
  • 01:00 meywd won the Freshman badge
  • 01:00 nayega won the Freshman badge
  • 01:00 gpfear won the Freshman badge
  • 01:00 Conrad925 won the Freshman badge
  • 01:00 skythra won the Freshman badge
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
  • 01:00 patlabor44 won the Uniformed badge
