I was beginning to re-install winxp --- I left while it was reformatting --- when I came back the screen said "setup cannot copy the file ks.sys"
I pressed enter to re-try -- now it had the same error message for several other files (modem.sys, parport.sys, wdmaud.drv, pjlmon.dll, etc)
I kept pressing enter, and eventually the progress bar reached 100%.
But after the pc rebooted, I was back where I started (Again I was given a choice in which drive to install in; whether to reformat the drive as FAT or NTFS, etc)
i have the same problem... setup cannot copy files kodak.etch... so id try to enter it dn't work... then i try again another cd XP home license it dn't work so i try again another cd XP pro dn't work and try again another DVDroom dn't work so what is the cause of that setup cannot copy file???
