Well this is a long story, i was very foolish and stupid, it all started when i went on my second partition which had windows vista beta 2 installed on it, well, i started fooling around and i messed something up, so, i went back into my partition 1 which had windows xp pro on it, so i went into a program on my computer called partition manager, and i deleted partition number 2, or i think i just formatted it again, not really sure, but, then i started downloading the vista beta again cuz i needed to reinstall, so then after the download finished, i restarted the computer and came across an error, windows boot manager wasnt allowing me to go into my first or 2nd partition, when i tried to go on my first partition with winxp pro, it said that ntldr.exe was corrupt, and when i tried on my 2nd, the one i supposedly formatted or deleted, it said boomgr.exe is corrupt, so what i did was installed windows xp 64 bit edition, but i am having problems booting into that as well because my monitor is blank and all it says is output signal out of range change to 1280 x 1024, so im running 64 bit edition in safe mode right now, but what i need help is booting into my winxp pro partition, please if someone can help it would be greatly appreciated, i still have access to my partition btw, i can access the files and stuff my going in my computer and going into c but thats all i can do please help guys..............
