OK I'm pretty fucked, here's my situation:
I have 2 IDE hd & 1 SATA, my 2 IDE are split into two partitions, the first partition is my Windows OS, 2nd partition is a SUSE linux OS. 2nd hd, 2 data partitions, and my sata, the biggest hd of em all, only has data, A LOT. And my most important data, schooldocs, installers, movies, pics, music, everything.
Now i have this organisation for years now, never had any probs, and for some reason I suddenly started getting errors on my SATA hd (H: btw).
Error 1:
http://users.telenet.be/i_dislike_mushrooms/error1.JPG
I can open my H: disk, but here's where the story ends, when i try selecting something I get this error:
Error 2:
http://users.telenet.be/i_dislike_mushrooms/error2.JPG
For some reason it just doesn't recognize the disk anymore.
I tried formatting my pc (not that this is a solution, but it was needed )
Sometimes I can select a map and open a file, but then it's start erroring again and i can't do shit anymore.
When I use my linux, it can still open my H hd and use the files... (although it's a bit slower than usual)
Please, I mean really, pleeeeaaaase, is there any way I can fix this?
If I lose these files I'm sooo fucked.
Thanks so much
Error 1:
Error 2:
Thanks so much
