Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > Will all decent GPUs in the future need 2 6-pin power?
Forum CPU & Components : Power Supplies, PC Cases & Case Mods - Will all decent GPUs in the future need 2 6-pin power?
So I have been researching my build for a while now and I thought I was finished choosing components, until today.
The 8800GTX needs two 6-pin connections from the PSU, thus leading to a PSU with 4 6-pin connections for a SLI set up. I was planning a getting a 8800GTS and eventually going to SLI with that. So for the time being I will only need 2 6-pin connections on my PSU anyway.
My question is what about the 9XXX gen cards? Do you think that the high end 9XXX cards are all going to need 2 connections each? Maybe the chips will be super efficient and will not need it? Will PCIe 2.0 supply more power through the mobo? Will I want a new PSU in a year and a half anyway?
I was planning on getting the OCZ GameXStream 700W for $125 after rebate, but now I am looking at the SILVERSTONE ST75F 750W for $160.
Your opinion please.
Sponsored Links
i imagine if you have enough amps on the combined 12v rails you can just buy a pci e splitter(cheap) http://www.newegg.com/Product/Prod [...] 6812201003
Reply to lewbaseball07
Quote :
Correct me if I'm wrong, but the connectors really don't matter, except perhaps for cable neatness, and a slight increase in resistance. You just get the appropriate adaptor. For instance:
http://www.newegg.com/Product/Prod [...] 6812887001
Couldn't you just get two of these and go from the Molex? (Not that this is very likely on PSUs that have the required wattage and ampage, because they will probably have the right adaptors anyway) Why does the actual connector matter?
Reply to jamiepotter
If we consider the development of graphics cards, we will see that, as power requirements increase, solutions are implemented to support these increased requirements using the existing technoliogies available (the restrictions being the power supply - rating and connectors available). Special connectors are developed where necessary.
As these new solutions are implemented, the power supply manufacturers develop higher-rated power supplies. Special connectors required by the card manufacturers are implemented also.
The pattern I see is as follows:
1. Card manufacturer develops a new connector when it requires 2 existing power supply connectors to be connected, and supply cable adapters that take 2 existing connectors and join them into the new connector
2. Power supply manufacturers develop new supplies adding these new connectors as standard to their new power supplies (providing the additional power required directly to these new connectors)
3. Card manufacturers develop a card that utilises 2 of these new connectors
Rinse and repeat.
At some point in the near future, I would expect a new connector to be developed together with a cable adapter, as we have now entered stage 3 with the 8800GTX.
Reply to aoe
I don't see why they don't just use thicker cables and use copper instead of tin plated steel..
Soon we'll have a 24 pin connector to the GPUs at this rate :P
Reply to asdasd123123
Thanks for the input. I know there are adapters for power cables, and that you can always mix and match them to get the correct connection. My concern is whether they will affect stability on something as important as the GPU. Do you think using adapters with a quality PSU such as an OCZ would have little or no effect on stability?
I saw that there was a 8-pin on the Silverstone OP750 750W, along with the four 6-pin connections, which is $10 more than the ST75F that I was considering. Now I know where that $10 is going.
mpilchfamily you were getting to the heart of my question with your final response. I assume smaller manufacturing processes will lower power consumption, I just wonder to what extent.
I have not yet looked into the specifics of the PCIe 2.0, does anyone know if there will be more power provided via this new standard?
Reply to Wrick
Quote :
The reason is simple. Copper is a soft metal. After a couple of times of plugging and unplugging the connector the connection would not be very tight. This leads to more resistance in the connection, arking in the connection that can cause spikes in the power flow and corrosion. All of which lead up to rapid PSU failyer. You need the steel to help maintain a tight connection. The tin is added to prevent curosion and to help the transfer of electrons. There are several PSUs that use gold plating.
Add to that the fact that while pure copper is an excellent conductor, oxidized copper is terrible. So even if the pins were copper core, they would still need to be plated with something to prevent oxidation. Also, many of the metals that work well for plating copper (nickel and cadmium among others) are on the EPA's "discouraged" list because of some of the biproducts of mining and refining them.
Steel is a crappy conductor though. I would think that most of the current goes through the tin and the steel is mainly for mechanical strength. Like high voltage power lines are frequently steel core with aluminum around it. Steel's poor conductivity is what helps make transformers possible, the core losses would be very high if the core material (steel or other iron derivatives usually) were a good conductor due to eddy currents.
Reply to senor_bob
Eddy currents... who came up with a name like that? They should have left it as Foucault current, it sounds more technical.
Reply to randomizer
There are 542 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
