My configuration is: Asrock 4CoreDual-VSTA LGA 775 Motherboard, Intel D 915, 2x512 DDR 400, ATI Radeon 9550 256 mb 128 bit AGP, PCI tv-tunner ASUS MyCinema P7131 DUAL, 200gb SEAGATE SATA 150.
I am running Windows XP and I am able to install the 10/100 onboard LAN (VIA Rhine II), but the local area connection alway prompts "network cable is unplgged". I have tried the enable/disable bios setup command several times but no luck. I have tried several bios setups and the default settings also but still no luck. I am absolutely sure the cable is working for when i plugg it in another PC it's working. I have tried setting IP's and DNS's but won't work (obviously since I get "network cable is unplgged" wouldn't expect it to work this way ). I have used my waranty and exchanged the motherboard for another one (same model). Still the same problem. PLEASE HELP !!!!!
