Hey Guys I am looking to get a router and the problem I have is do I go wired or wireless.
And is it possible to go wired with a wireless router all the same ports are at the back.
Both of my computers are beside one and other.
I do alot of online gaming also the rouiter I am looking at is the
Netgear / WPN824 / 108Mbps / 802.11g / 4-Port / Cable/DSL / RangeMax Wireless Router
Wired is faster. Even if you buy a wireless router, you can still use wired, becuase they usually have 4 wired ports.
If the computers are close, I would recommend wired and gigabit if you can afford it. Get a router with built-in firewall for maximum safety.
Tom's hardware has some router charts you can consult prior to buying.
Wired is almost always quite a bit faster. The "108 Mb/s", "125 Mb/s", and even "54 Mb/s' are signalling rates well above what you would see in real data throughput, even with short distances and an interference-free environment. This is known as "marketing crap".
Wired can come very close to its advertised rates.
