jump drive speed
Forum Windows XP : Windows XP General Discussion - jump drive speed
Archived from groups: microsoft.public.windowsxp.basics,microsoft.public.windowsxp.general,microsoft.public.windowsxp.newuser (More info?)
i have a lexmark jump drive, when I use it on my windows 2K machine R/W
access is reasonably fast; however, when I use the same removable drive
on my windows XP (home) computer, access to the drive is god aweful
slow. Can this be fixed ?
Woodzy
http://www.rtdos.com (alt OS for games based on the classics)
http://o.webring.com/hub?ring=awrbr ( AbandonWarez ring )
Sponsored Links
Do you need updated drivers for it?
Harry Ohrn MS-MVP [Shell/User]
www.webtree.ca/windowsxp
"(ProteanThread)" <rtdos@rtdos.com> wrote in message
news:uRpvejwPFHA.3928@TK2MSFTNGP09.phx.gbl...
>access is reasonably fast; however, when I use the same removable drive on
>my windows XP (home) computer, access to the drive is god aweful slow. Can
>this be fixed ?
> Woodzy
Reply to Anonymous
how can i update my usb drivers ? windows update has never told me to
update them.
Woodzy
Reply to user
If the home computer is even a few years old it probably has USB 1.0. To
increase the transfer speed you will need USB 2.0. You can get a four port
USB card for about $20. Easy to install and worth the cost.
To verify your USB capabilities,
Right click on My Computer
Properties
Hardware Tab
Device Manager Button
At or near the bottom of the list double click
Universal Serial Bus Controllers
If you don't see the word enhanced in the list, you have USB 1.0
Don
Vancouver, USA
>this be fixed ?
> Woodzy
Reply to Anonymous
I would imagine you have a "Lexar" jump drive instead of the stated
"Lexmark". As another poster to this thread states, if your "reasonably
fast" computer has USB 2.0 and the other computer does not; there, very
likely is your answer to the access speed difference.
Gene K
>this be fixed ?
> Woodzy
Reply to Anonymous
That should be "Lexar" and not "Lexmark".
What model of Lexar Jump Drive?
>this be fixed ?
> Woodzy
Reply to Anonymous
Archived from groups: microsoft.public.windowsxp.basics (More info?)
Generaly I don't update drivers recommended by Windows -
however if I'm having difficulty with a device, then I
will check for updated drivers.
xfiler
>-----Original Message-----
never told me to
>update them.
>Woodzy
classics)
ring )
Reply to Anonymous
news:OHgyPH2PFHA.1268@TK2MSFTNGP14.phx.gbl...
> update them.
> Woodzy
The Windows Update Site is not reliable when it comes to drivers. Visit the
Lexmark site and see if there are updated drivers available.
Reply to Anonymous
>>this be fixed ?
>>Woodzy
sorr, should be lexar; its a 128 meg media drive w/secure feature.
Woodzy
Reply to user
If the Jump Drive is not USB 2.0, connecting it to a USB 2.0 port will not
increase the speed.
In memory of our dear friend, MVP Alex Nichol.
Michael Solomon MS-MVP
Windows Shell/User
https://mvp.support.microsoft.com/communities/mvp.aspx
Backup is a PC User's Best Friend
DTS-L.Org: http://www.dts-l.org/
"Don Schmidt" <RetiredEngineer@pnb.telco> wrote in message
news:115nm221k5bb890@corp.supernews.com...
> Properties
> Hardware Tab
> Don
> Vancouver, USA
>>Can this be fixed ?
>> Woodzy
Reply to Anonymous
You should check the manufacturer's website for the latest XP compatible
drivers for the drive.
Windows Shell/User
news:ePxYiP%23PFHA.3628@TK2MSFTNGP15.phx.gbl...
>>>on my windows XP (home) computer, access to the drive is god aweful slow.
>>>Can this be fixed ?
>>>Woodzy
> Woodzy
Reply to Anonymous
thanks
Woodzy
Reply to user
You're welcome, hope it helps.
Windows Shell/User
news:OJK%234HPQFHA.924@TK2MSFTNGP14.phx.gbl...
> thanks
> Woodzy
Reply to Anonymous
Archived from groups: microsoft.public.windowsxp.general (More info?)
> Woodzy
Are you sure that the XP machine doesn't have USB 1.1 and
the 2K machine USB 2.0?
Reply to Anonymous
>>Woodzy
actually its the other way around, win2k machine has usb 1.1 and xp has
2.0 (verified this)
Woodzy
Reply to user
"slowness" is often due to using old drivers for the hardware.
http://www.bootdisk.com/
Reply to Anonymous
update them.
Woodzy
Reply to user
It's not the USB drivers you need to check, it's the drivers for the jump
drive that need to be checked. You may find updated drivers for the jump
drive at the jump drive manufacturer's website.
Windows Shell/User
news:%23C0jWH2PFHA.1268@TK2MSFTNGP14.phx.gbl...
> update them.
> Woodzy
Reply to Anonymous
Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > jump drive speed
There are 591 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
