Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > Suggested Power Supply for the 8800GTS
Forum CPU & Components : Power Supplies, PC Cases & Case Mods - Suggested Power Supply for the 8800GTS
I've just recently bought an NVIDIA 8800GTS EVGA PCI-E 320MB card and I'll be using a 500W power supply. Do you guys think the power supply will be enough for it or do you think I should go higher? Say a 600W power supply. Thanks for the feedback.
Sponsored Links
Read the PSU 101 sticky at the top of this section.
We need more then just wattage, after you read the sticky you'll understand. What's the brand and model?
Reply to apt403
Thanks for the reply and advice to read the sticky. I didn't know too much about power supplies before reading that. I've been searching on the net trying to find some information about how much power this psu puts out but I can't seem to find anything. However, the name of it is: NZXT PF-500 500Watt Power Supply.
I've read that the brand "NZXT" is only purchasable by getting a NZXT case (which I did). The case name is: X-Discovery Mid-Tower Case 420W.
Also, I've been reading how this specific power supply isn't compatible with SLI motherboards. The motherboard I have is...well, here's my specs...
CPU: Sckt775)Intel® Core™ 2 Duo E6400 CPU @ 2.13GHz 1066FSB 2x1MB L2 Cache EM64T
Case: X-Discovery Mid-Tower Case 420W
Power Supply: NZXT PF-500 500Watt
CD Drive: 18X DVD±R/±RW + CD-R/RW DRIVE DUAL LAYER
Fans: INTEL LGA775 CERTIFIED CPU FAN & HEATSINK + 3 EXTRA CASE FANS
Motherboard: (Quad-Core Supports) Asus P5N-E nForce 650i SLI Chipset LGA775 FSB1333 DDR2 Mainboard
Memory: OCZ PC2 6400 2GB(2x1GB Dual CH)
Video NVIDIA 8800GTS PCI-E 320MB EVGA
Thanks again for your help, I appreciate it.
Reply to Nev3render
Thanks for the reply mpilchfamily. I'm looking at the OCZ GameXStream.
OCZ GameXstream 600W 48.33A 2 x 6pin NO ACTIVE (80%-83%) $130.00
Any suggestions and/or experiences with this PSU?
Reply to Nev3render
- 0 +
I concur. You need a new psu. Not enough power and NZXT is a pretty crappy brand when it comes to power supplies.
I would get either a Corsair 520HX or the PCP&C 610w Silencer, but any psu on mpilchfamily's list is awesome.
The GamerXStreams are decent, but not to popular around here. The 520HX is a better quality unit for the same price.
Reply to apt403
So let me ask you this. If I power up my system with the NZXT 500W that came with my PC, could it fry my video card? My mobo? Anything?
Reply to Nev3render
- 0 +
Bad quality PSUs tend to die faster then quality units, when a PSU dies there's always the chance it could take a couple components with it. It also has a pretty low efficiency, 65%, so it'll consume more power then a high quality unit.
Reply to apt403
I've checked out the Corsair 520HX. Seems to be pretty superior (compared to the GameXStream) from what I've read in reviews. By the way, I love this forum. The next time I build a system I will definitely be seeing what you guys here think. Thanks A TON.
Reply to Nev3render
Just got my new PC today, popped in the 8800GTS 320MB and the 2GB OCZ RAM and it's running pretty well. I haven't tested it out too much and I'm probably not going to. Not until I get my new power supply. I've decided to go with the OCZ GameXStream ATX12V 700W Power Supply. I've been reading reviews on how it's really quiet, light, and an overall really good power supply. I've never owned any OCZ products until now, and from what I'm experiencing right now, I'll be buying their stuff from now on. Thanks again guys!
Reply to Nev3render
There are 1467 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
