Yes No
Ads
Tom's Hardware > Forum > Home Theatre > HDTV > Using a RP HDTV as a computer monitor.
Forum Home Theatre : HDTV Using a RP HDTV as a computer monitor.
Archived from groups: alt.tv.tech.hdtv (More info?)
Greetings!
My wife and I are just about to buy our first hdtv. The models we set
our eyes on are both from SONY, KDF-60XS955 or the KDF-60XBR950. We
are currently trying to see if the extra features the XBR brings are
worth the $500.
The computer plays a pretty significant part in our lives. We watch
news, movies, play games and surf the net on a daily basis.
Would any of the two tv's we are thinking to get work as a computer
monitor? Not necesarely as a full time monitor but just for when
playing a game or watching movies or for simply browsing the net using
a wireless mouse/keyboard while on the couch?
I see that both of these TV models we are looking at have similar
types of inputs (below)
7 A/V inputs, including:
4 composite video (3 rear, 1 front)
4 S-video (3 rear, 1 front)
2 rear-panel HD-compatible component video
(accepts 1080i/720p/480p/480i signals)
1 rear-panel DVI with HDCP copy protection
I also have a computer with a Radeon 9800XT video card which has a
normal monitor output and, at the risk of sounding like a moron, the
square white output plug which I have seen on HDTVs as well.
Will this work right away? WIll I need a different type of video card
or any addapters, cables or converters?
Thank you very much.
Cori Stepan
p.s. This is my seccond attempt on posting this message. The first
time I could not find my post anywhere. If somehow I posted twice I
would like to sincerely appologize.
Reply to Anonymous
I don't think it will work. I have an HDTV that I use as a monitor, and the
HDTV has VGA in. The "white" plug you are referring to is DVI out for a DVI
monitor, and I will caution you, that the DVI in on HDTV's is not the same,
it's usually only intended as an input for DVD players.
Look for a HDTV that specifically supports VGA.
Now, I'll step aside so I can be corrected :)
"Cori Stepan" <coristepan@yahoo.com> wrote in message
news:899f10ef.0410271338.349bef3c@posting.google.com...
> Greetings!
> worth the $500.
> Cori Stepan
Reply to Anonymous
Should work fine, though you will not go in through VGA (since you don't
have one!) but through component. Your Radeon card will have a component
HDTV converter (three connectors) which should do the trick. If it doesn't,
you can get one from ATI. Be sure you have updated Catylyst drivers, so you
can take advantage of ATI's recent support for widescreen modes.
"Homeofmike" <news@homeofmike.com> wrote in message
news:1ZWfd.18601$R05.5051@attbi_s53...
>the HDTV has VGA in. The "white" plug you are referring to is DVI out for
>a DVI monitor, and I will caution you, that the DVI in on HDTV's is not the
>same, it's usually only intended as an input for DVD players.
>> Greetings!
>> worth the $500.
>> Cori Stepan
Reply to Anonymous
Using a Plasma Display for a computer monitor, Sure it should work quite
nicely with the appropriate hardware and connection cables. However, set
your screen saver for a max of about 15 min. That way you will not see all
of your icons permanently become part of the plasma display. Sony
discourages using plasma sets as a computer monitor because of the high
possibility of permanent burn in.
"Helen Chevy" <helenchevy@hotmail.com> wrote in message
news:vCYfd.327627$D%.320261@attbi_s51...
> doesn't, you can get one from ATI. Be sure you have updated Catylyst
> drivers, so you can take advantage of ATI's recent support for widescreen
> modes.
>>the same, it's usually only intended as an input for DVD players.
>>> Greetings!
>>> worth the $500.
>>> Cori Stepan
Reply to Anonymous
Okay, I'm just lost with the DVI interface and cables.
I've got a Samsung DLP HDTV and it has PC (VGA) and a female DVI input.
I also just got a Dell computer and it has DVI output via a 15 pin female
connector. Intel 82159G Express Chipset.
So I want to display my computer on this (no other monitor).
So do a use (and will it work) a:
DVI-A male to HD15 male analog video cable?
http://www.cablestogo.com/product. [...] &sku=26954
TIA
"Art" <plotsligt@comcast.net> wrote in
news:ZvCdnYZW2-LAIh3cRVn-rw@comcast.com:
> quite nicely with the appropriate hardware and connection cables.
> However, set your screen saver for a max of about 15 min. That way you
> will not see all of your icons permanently become part of the plasma
> display. Sony discourages using plasma sets as a computer monitor
> because of the high possibility of permanent burn in.
>> don't have one!) but through component. Your Radeon card will have a
>> component HDTV converter (three connectors) which should do the
>> trick. If it doesn't, you can get one from ATI. Be sure you have
>> updated Catylyst drivers, so you can take advantage of ATI's recent
>>>and the HDTV has VGA in. The "white" plug you are referring to is
>>>DVI out for a DVI monitor, and I will caution you, that the DVI in on
>>>HDTV's is not the same, it's usually only intended as an input for
>>>DVD players.
>>>> Greetings!
>>>> set our eyes on are both from SONY, KDF-60XS955 or the
>>>> KDF-60XBR950. We are currently trying to see if the extra features
>>>> the XBR brings are worth the $500.
>>>> using a wireless mouse/keyboard while on the couch?
>>>> the square white output plug which I have seen on HDTVs as well.
>>>> card or any addapters, cables or converters?
>>>> Cori Stepan
Reply to Anonymous
There are 2009 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Sound Bars
By americanaudiophile, 23 days ago:
If you want to connect the receiver zone 2 to the soundbar then you need a speakers to...
Best offers
