SSD - The Performance Upgrade of the Future
i have wireless connected and LAN connected i want the traffic to use the wireless first, then try the lan
By default it will use the first connection. So you will need to have the ethernet disconnected till after the wireless is up.
Why would you want it to prefer wireless when wired is present? Are you into "slow" for some reason?
You are about to answer a thread that has been inactive for more than 6 months.If you still wish to proceed, please ensure that your posting is original and does not duplicate or overlap any prior responses to this thread.
